Mar 29, 2021 3:41 PM UTC
Blocking Sessions in PLM from the Database or from any other source
Hi All,
Can we all know through an SQL Query or a procedure the list of all blocking sessions in PLM which is blocking other processes to wait or run lately?
In case if this cannot be done through DB can we do it through any other means.
Mar 30, 2021 12:34 PM UTC
Aachanta,
If you're having a specific issue, with blocking sessions, you could check out this knowledge article we have published:
https://www.ptc.com/en/support/article/CS66532
It's an oft-used article, to help identify blocking sessions, or why DB transactions seem to be hung or stuck.
If you are having an issue like that, I'd suggest opening a Support case.
Mike
Aachanta,
Mike
