Jun 24, 2024 10:52 AM UTC
BOM Redlining Report
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.1
We plan to implement BOM Redlining in Windchill. As I understand the current functionality, when an ECN is in an open state with BOM Redlining and we run a summary report, it does not display the added or deleted objects. However, once the ECN is released, they are included in the report. Is it possible to configure the report to show BOM redlining details while the ECN is still in an open state?
    Aug 12, 2024 2:15 PM UTC
    Hi Charles,
    I checked with PTC Support,they mentioned it is not possible because of the way redlining works.
    Thank you for your support.
    -Srinivas
    avillanueva
    23-Emerald II
    Jun 25, 2024 10:49 AM UTC
    Can you send screen shots?
    18-Opal
    Jul 10, 2024 8:32 AM UTC
    Hello Srinivas_256,
    Do you still need help ?
    KR,
    Charles.
    Srinivas_25612-AmethystAuthorAnswer
    Hi Charles,
    -Srinivas
    11-Garnet
    Sep 10, 2024 7:25 PM UTC
    The Change Notice Summary Report capability has been extended to support Affected Objects as well as Resulting Objects. This capability was released in Windchill 13.0.2.0. You should now be able to run your report and get the same results prior to the CN being released.
    Nick
