Aug 8, 2024 7:56 AM UTC
BOM Structure Comparison
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS14
1、BOM结构对比结果以行号进行排序,希望对比结果“无对等对象”也按行号排序进行展示
2、目前当结构上行号相同,但差异项结果为“无对等对象”时,未按行号进行排序,此类场景在结构最末尾展示
3、当两个不同的零部件进行BOM结构对比时,希望将相同行号在一行进行展示
Translated by the moderation using Google Translate
1. The BOM structure comparison results are sorted by line number. It is hoped that the comparison result "No equivalent object" can also be displayed in order by line number
2. Currently, when the line numbers in the structure are the same, but the difference item result is "No equivalent object", it is not sorted by line number. Such scenes are displayed at the end of the structure
3. When two different parts are compared in BOM structure, it is hoped that the same line numbers will be displayed in one line
Catalina
Community Manager
Aug 12, 2024 10:08 AM UTC
Hi @汪冬_11347082,
Thank you for your question.
Best regards,
Catalina
PTC Community Moderator
Catalina | PTC Community Manager
Aug 14, 2024 4:26 AM UTC
As mentioned by Catalina, a screen shot will help.
