8-Gravel
Oct 31, 2023 12:48 PM UTC
BoundingBox attributes vs boxextents - unexpected results
Having an issue with a calculated attribute on EPMDocument type to determine material thickness. Using attributes noted in CS324653 and using the supplied code for minimum model extent size  - the returned value  of the new attribute is not correct.
As an example - when looking at the values in /servlet/odata/v3/CADDocumentMgmt/CADDocuments('{CADDocumentId}')/Representations for a sample part - the value for 'BoundingBox' is:
      "BoundingBox": [
        -0.0533878,
        -0.0673053,
        0,
        0.0860431,
        0.441427,
        0.009525
This data appears correct and are dimensions measured from the main part planes.
For this example - if Az is BoundingBox[2] and Bz is BoundingBox[5], then `BoundingBox[5] - BoundingBox[2] = 0.009525` which is correct for this part.
However, if I create a new calculated attribute on the CADDocument type (BoxThicknessmin), and set the formula equal to `abs(boxExtents.Az - boxExtents.Bz)`, the value I get for this new attribute is `"BoxThicknessmin": 0.014859520749434692` which is incorrect.
An incorrect valve is shown even if I make a direct attribute relationship without a formula (e.g. simply put BoxExtents.Bz as the formula).
Does anyone have any suggestions or explanations on why the calculated value has an unexpected result? Are there any server logs that we could lookup to debug this issue?
20-Turquoise
Oct 31, 2023 1:31 PM UTC
As a warning the "bounding box" dimensions stored in Windchill are the useless size with datums:
Windchill PDMLink: Is it possible to show the value of EPMDocument boxExtents.* attributes without considering datums?
HelesicPetr
Oct 31, 2023 1:33 PM UTC
Hi @AW_ME
A value is stored In a database but this value can represent some Measurement System. The value is different for SI and for  USCS
Check what is set in the model, and check what is really in the database and what is shown with the calculated attribute.
Also check if the visualization is really actual and everything has been regenerated in the model.
Based on config the visualization is regenerated during visual process but user can forget to do so.
PetrH
Mar 12, 2024 11:43 AM UTC
Hi @HelesicPetr
I'm trying to make use of the BoxExtents data as well.
Some of our models are in SI units, some use the USCS measurement (*sigh*) system.
Do you know if there is a way in WT to detect the measurement system for a given EPMDocument?
Regards
20-Turquoise
Mar 12, 2024 1:44 PM UTC
@PN_5076692 wrote:
Hi @HelesicPetr
It does not matter what the model unit system is. The values are stored in Windchill as meters.
