avillanueva
23-Emerald II
Aug 15, 2018 7:47 PM UTC
Bug Found with creating and renaming notes. fixed in 11?
Here is a simple test if someone can confirm this. Create a note object. Number it "NOTE1". Rename it and change the note to "NOTE2". Go back and try to create a new note numbered "NOTE1". Reply back if you get a uniqueness error on creating the second note. Search for "NOTE1". You should find nothing.
What I noticed is that since notes are EPMDocuments but do not have a filename (aka CADNAME), they are created with a CADNAME that matches the number.  Rename actions to change the number do not have a filename field hence CADNAME cannot be change. CADNAME must be unique so that is why you get the error.  Reported bug to PTC.  Tested this on 10.1.
BenLoosliAnswer
Aug 15, 2018 9:26 PM UTC
Duplicated it on 11.0 m030 cps08
BenLoosli23-Emerald IIIAnswer
avillanueva
23-Emerald II
Aug 20, 2018 1:38 PM UTC
Thanks. PTC confirmed it too. SPR generated.
