avillanueva
23-Emerald II
Apr 18, 2024 11:47 AM UTC
Build Failed-Publish to CAD-unsupported CAD application.
I've been updating some attributes with WTParts and got this error message in Event manager:
Build CAD from Part failed: The associated Cad document (CAD Part  - 94805a115.prt, -.2) is authored using an unsupported authoring application.
I can confirm that the model is a Creo model and shows authoring application as Creo from 2014. Is this something that fails if models were uploaded using an older version of Creo and never touched since? What version does this work after?
Apr 22, 2024 6:41 AM UTC
May be the Creo Version of that CAD Model is not compatible with your Windchill version. You can open and save once the CAD model and check in, so that windchill is aware of the Pro/E version ( oops, Creo Version).
Cheers
Hari
