Apr 8, 2020 9:46 AM UTC
Bulk Data Migrator installation
Hello everyone,
 I know that for Bulk Migrator 11.xx i should use the PSI to install the product.
Now I ask if the lightweight installation (using ant) is still valid.
Thank You
Giorgio Fontana
Aug 13, 2020 12:48 PM UTC
Some structures and tables are missing after installation by ant -f xx lwi_WBM.xml.
You need run those scripts from newly created folders from WbmCore:
@create_WBMDateRec_Struct_0.sql, @create_WBMNumberRec_Struct_0.sql, @create_WBMVarcharRec_Struct_0.sql ,@create_WBM_DATE_TABLE_Array.sql
And this workaround is not supported.
