11-Garnet
Mar 22, 2025 6:10 PM UTC
Bulk deletion of attributes in windchill
hi team,
There is a scenario I need to delete 75 attributes in windchil
This is tedious and can we have a bulk deletion loader or how can it be done through build deployment?
11-Garnet
Mar 24, 2025 6:05 AM UTC
@HelesicPetr  can u guide on this or route to guide?
HelesicPetr
Mar 24, 2025 7:02 AM UTC
Hello @SS_10574885
You can use load from file method.
Here is an article describing how to load attributes to the system.
CS30168 - How to export and import soft types and attributes using 'LoadFromFile' in Windchill
If you import one attribute, and system contains additional attributes then the method generate XML file in a Windchill/temp folder for deletion the additional attributes.
You can use the load from file method to load the generated xml to delete the attributes.
PetrH
Aug 29, 2025 7:39 AM UTC
Hi @HelesicPetr
Approach you have suggested only delete the attribute created in type  Is it possible to delete the attribute created in Manage Reusable Attribute via LoadFromFile  ?
