AF_mechdesigner
Bulk export of CAD files from Windchill with automatic reassignment of file names
Version: Windchill 12.1
Use Case: Bulk export of file according to customer requests
Description:
Hello everyone,
I searched on Windchill helpcenter, but coudn't find a complete answer.
Does anyone know if it's possible to perform a "bulk export" operation of CAD files from Windchill with automatic reassignment of file names?
This is the scenario:
1) I have .asm files (Creo) and Catproduct (Catia V5) files stored in Windchill commonspace, each one having their file name according to company rules.
2) All the files (.asm, .prt, Catproduct, Catpart) also have designated Windchill parameters that include the appropriate number defined according to customer rules (hence differing from the current file name)
3) Ideally, I would export a selection of .asm and Catproduct files, including all the "Dependent" items and save them to a local folder for subsequent transfer to the customer's PLM
4) Before sending the files to the customer, I would need a bulk rename operation which modifies ALL FILE NAMES making them equal to the "customer part number" parameter which is visible in Windchill. This is mandatory before uploading them on the customer's PLM and cannot be done via Windows CMD, because this would break any asm/prt relation
5) Of course I would need Creo and Catia assemblies to maintain their structure, so that the customer can retrieve the assemblies (.asm / Catproduct) without "retrieval failure" errors.
Is this available in Windchill out-of-the-box or did someone create their own script to perform this task?
Thank you, regards
d_grahamAnswer
18-Opal
November 14, 2024
Yes, I wrote a utility to do it that runs from a Windchill shell.
It took about 3 hours to export ~400 GB of data.
It also puts the cad files in a Windows folder structure that mirrors the Windchill folder structure the CAD Docs are in.
It worked great.
I also have a utility to export an assembly or assembly drawing with all dependents.
d_graham18-OpalAnswer
18-Opal
November 14, 2024
It worked great.
AF_mechdesigner
@d_graham Thank you for your reply.
I was expecting that this functionality is not available out-of-the-box, but it's good to know that you succeded in creating a custom Windchill shell.
Processing time is not a problem, as this could run overnight without overburdening the server while users are checking in/out CAD data.
