Mar 6, 2012 2:05 PM UTC
Bulk reassignment of life cycle and team templates
We have a requirement to reassign many thousands of lifecycles and team templates. Would anybody be able to offer any tips/methods to achieve this in bulk, perhaps via the Windchill shell? It would be extremely time consuming/impossible to do it through the UI due to the high number objects involved. We are using WC 9.1 M062
More specific requirements are
1) Select all objects
Of a specific type
(Optionally) Within a specific context
(Optionally) With a specific current lifecycle template
2) And reassign
To a different template (by name)
In the case of lifecycles, specifically setting the state
Kind regards
Darren
MarcoTosin
Nov 6, 2015 11:32 AM UTC
Darren,
I've done some search in the community, but haven't found a solution for your request.
After more than three years, have you got any solution for bulk reassignment of LC templates that you could share?
Marco
Nov 6, 2015 11:54 AM UTC
Marco
have not looked at this for while but it is most definitely still on the to do list. Last I looked there is a utility provided by PTC which is documented but it has limitations regarding reassigning but maintaining current state.
http://support.ptc.com/cs/help/windchill_hc/wc101_hc/index.jspx?id=LCTempCommandUtilIntro&action=show
Regards
Darren
