May 29, 2023 2:55 PM UTC
BulkIndexTool
I have tried to run wt.index.BulkIndexTool.
gets the below error from shell,
"You must login as a user from the Administrator group.
ERROR: You must login as a user from the Administrator group.
You did not successfully authenticate as a user from the Administrator group."
any suggestion?
Thanks!
avillanueva
23-Emerald II
May 30, 2023 12:14 PM UTC
Can you answer the obvious? Are you part of the site administrators group? Did you use your login or wcadmin?
Try to verify authentication works:
https://www.ptc.com/en/support/article/CS338401?source=search
NSS14-AlexandriteAuthor
May 30, 2023 2:20 PM UTC
Yes, I am part of site admin group.
I have tried using "wcadmin" as well as "my login"
