Apr 19, 2023 7:09 PM UTC
Byte Error Message while creating a Change Request
I am trying to create a Change Request.
When I reach the character limit with more than one paragraph on Description, Comments, Proposed Solutions and Status attribute fields, I see the bytes error message.
The number of bytes in this attribute value can be no more than 4000. The number of bytes currently entered is 4014.
Does anyone know how to resolve this problem? does it have to do anything with OOTB file? are there any articles on PTC support which I can refer to?
avillanueva
23-Emerald II
Apr 19, 2023 7:14 PM UTC
You've blown out the table column size in the database. This is a hard limit on text fields. One of your text fields has a novel in it. Try to shorten it or attach a document with the text you want in it.
Apr 19, 2023 7:22 PM UTC
is there a way not to see this error and it just gives only the character limit error? because normal user can not understand this error message.
avillanueva
23-Emerald II
Apr 19, 2023 7:29 PM UTC
Here are some articles:
https://www.ptc.com/en/support/article/CS324817?source=search
https://www.ptc.com/en/support/article/cs360416?source=ArticleViewerRelated
If you are looking to suppress the message, possible with extensive customization but I do not recommend. Easier to train users to write less in text fields and if they get too big, put it in a file attachment.
Apr 19, 2023 8:27 PM UTC
Probably not related, but have you seen this?
https://www.ptc.com/en/support/article/CS384293
