Nov 6, 2014 11:42 AM UTC
CAD Agent Administration - Trying to configure an Agent, and failing...
Hi All,
I'm trying to configure an Agent for Creo 2.0 on a Windchill 10.2 monolithic install. I'm failing.
I've completed the set up using proe2pv_config and ended up with a proe_setup folder that contains a number of batch files that proe2pv_config generated.#
I then go into WC10.2 Worker Agent Administration to configure the new worker. This is where I get lost and confused.
ADD WORKER
I tell it the server name
I tell it the DATATYPE (I've selected PROE)
Worker Location
I tell it where the server is. (The Windchill server)
Worker Execution Command
I'm not too clear about this... I've told it the following;
'C:\ptc\creo_view_adapters\proe_setup\proeworker.bat' (This is where proe2pv_config created the bat file)
I apply the settings, save the file & Return to the Worker Agent Admin screen.
I see the new Agent in the list, Fab! but the Status is "Fails to Start". The flag under Actions is White & the tooltip states; "Executable not Safe".
Additionally the methodserver log has the following entry;
ERROR : wt.wvs.workeragent.ShapeType - Refused to start worker ukbas1wcs2-PROE:1, exe does not match any of the trusted prefixes
Can anyone shed any light on where I might be going wrong?
Many thanks!
TomU
Nov 6, 2014 1:20 PM UTC
Update or add worker.exe.whitelist.prefixes and worker.exe.whitelist.prefixes.<worker_host> properties in the <WT_HOME>/codebase/WEB-INF/conf/wvs.properties
See https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS140965
Nov 6, 2014 3:07 PM UTC
Thanks Tom,
I still can't get passed the error! I followed (I think) the example in the link you provided so now my wvs.properties file has the following entry;
worker.exe.whitelist.prefixes=C\:\\ptc\\creo_view_adapters\\proe_setup
this matches the agent.ini file;
[agent]
numworkers=1
port=5600
transferpath=$(wt.temp)\transfer
[worker1]
distributed=false
autostart=true
host=MYSERVER
autobusystop=
autoidlestop=
starttime=15
startfromlocal=FALSE
autoerrorstop=false
remotepath=
hosttype=local
localpath=ftp:
exe=C:\ptc\creo_view_adapters\proe_setup\proeworker.bat
password=
maxinstances=1
shapetype=PROE
prompt=
availabletime=
username=
port=601
But it still returns the same error and result.
Quite annoying...
Bob.
TomU
Nov 6, 2014 3:19 PM UTC
No, you don't list the entire path in the whitelist, only the partial path or drive.
For example, I have the Creo adapters installed on the "E" drive in a folder called "ptc". I have worker.exe.whitelist.prefixes = E:\ptc (use quotes when setting the value)
Nov 6, 2014 3:16 PM UTC
Hey Bob, this is a long shot, but is the GS Worker Daemon started on your CAD worker machine?
Buddy
Nov 6, 2014 3:20 PM UTC
Buddy,
I can honestly say that I have no idea! You've now introduced another factor I know nothing about!
How would I go about find out if it's running, and, if it's not, how do I start it?
Many thanks,
Bob
TomU
Nov 6, 2014 3:24 PM UTC
When you installed the adapters, did you let it install the worker as a service (it is a checkbox option)?
