Aug 2, 2011 1:14 PM UTC
CAD Documents - Tips on how to only set and show File Name
- 13 replies
- 14567 views
- Translate All
Are you setting CAD Document Number, Name and File Name all to the same value?
Let's use this discussion forum to document your techniques to simplify this for the user.
I am including a proposal below.
PROPOSAL 1:
- File Name is NOT generated (since deliverables, flexible components, etc.) usually use some part of Part number/name. For example spring.prt, spring.drw, spring.mfg, spring_expanded.prt, etc.
- Keep all other identifiers driven by File Name (9.1 or 10.0)
- Use OIRs to drive Number and Name from File name (see attached)
- Use server-side preferences to prevent File Name from being driven by Name or Number in New CAD Document, Save As and Rename
- Use Windchill 10.0 Type and Attribute Administrator to remove Number and Name from Layouts of UIs:
- CAD Document Information Page
- New CAD Document UI
- Use Table Displays to remove Number and Name from Tabular UIs (9.1 or 10.0):
- Workspace Listing
- Check In
- etc.
- Workspace Listing
- Users can continue to refine tables using Windchill 10.0 Table Controls to hide unwanted columns:
- Users can click on the column headers, choose the black down arrow, "Columns"
- User can show/hide any currently shown columns this way. The current display will be "sticky" until s/he changes it again (even after closing the browser and restarting a new session).
