3-Newcomer
Jun 16, 2026 5:51 AM UTC
CAD orientation is not showing correctly in windchill visualization tab and creo view.
The orientation of CAD representation in the Visualization tab in part structure browser and in Creo view is showing upside - down. while it is showing correct orientation when opening in Creo and also in the thumbnails in windchill.
Any solution is available for this ?
BryanKAnswer
Jun 16, 2026 10:03 PM UTC
This Link may have a clue to the solution. have a look a the note at the bottom of the call.
https://www.ptc.com/en/support/article/CS100785
Creo View can be used to visualize modern vs legacy orientations:
Navigate to Orientations > Customize and select Use legacy PV Standard orientations to auto convert the inputted values
This one explains why they are different
https://www.ptc.com/en/support/article/CS163032
And this may be a possible fix
https://www.ptc.com/en/support/article/CS27000
BryanK17-PeridotAnswer
