Nov 15, 2016 1:52 AM UTC
CAD Publishing
We are using PDF output for Creo Drawings. When a representation is generated by clicking on the thumbnail, the output of PDF is generated correctly. However, when we create a PDF through workflow expression code, the PDF is not generating correctly (datum planes are not coming correctly). Am I missing something in the code to pass any arguments ? @
