Apr 21, 2022 7:25 PM UTC
CAD Structure to wtPart View Structure Compare
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS08
How do I do a compare of a CAD Document (Creo Assembly) to a wtPart view that isn't the default Design? I need to do this so that I can then run the "Build One Level Part Structure" for the newly created "new view" of the assembly that was just set with the CAD Object as Owner.
Here are the errors that I faced
None
    TiloHAnswer
    20-Turquoise
    May 4, 2022 8:52 AM UTC
    sorry - it should be "Compare To CAD structure"
    Tilo
    20-Turquoise
    May 4, 2022 8:38 AM UTC
    Hi BrianToussaint,
    You could try the other way around:
    Open the WTPart with Manufacturing view and use then the 'Comapre to Part' action.
    /Tilo
    TiloH20-TurquoiseAnswer
    20-Turquoise
    Tilo
    May 25, 2022 11:25 AM UTC
    Hello Tilo,
    Since the view version did not give us the flexibility we needed if we needed to obsolete a view, we have actually gone a different route and added some customization to our process.  Instead of using the views we added suffixes at the end to act as our view.
    Thank you for the suggestions though.
    Brian
