CAD worker CAD software update makes worker not auto-start
  • September 23, 2024
  • 10 replies
  • 3114 views
Version: Windchill 12.0
Use Case: NX CAD worker (on VM). Just updated NX and went through the recipe and adapter files to confirm everything matches (ugworker.bat, ugstartup.bat, etc.) CAD worker fails to start from Worker Agent (monitor comes on). If I turn off the monitor there and manually launch ugworker.bat, everything works fine.
Description:
I updated my NX version on the CAD worker.
The worker now doesn't start up automatically. The monitor starts but in the worker log there's a 8 INIT error. When I turn off the monitor and manually run the ugworker.bat file everything works fine.
When I did the upgrade, I updated the ugworker and ugstartup files to reflect the correct NX version. Not sure what broke the auto-start... but I'm sure it's something silly.
What did I miss?
Best answer by Dobi
Found the issue!
Each worker has it's own Worker Daemon and port (CS49182) but for whatever reason, the NX worker was using the WorkerDaemon Service executable with the 9.0 adapter version instead of just the Worker Daemon.
Once I edited the service to remove the xxSVC, the worker fired right up.
launch adapter.pvi located in worker configuration directory (or launch command prompt, call <adapter_install_dir>\bin\pvilauncher.exe adapter.pvi), update NX version to one you installed on machine and click on setup. Revalidate your recipe files and other configurations like -su argument in ugworker.bat and ugstartup.bat availability.
I hope this shall work for you.
Dobi17-PeridotAuthor
@vdegaonkar i went through those steps after the software upgrade and confirmed that ugworker.bat and ugstartup.bat are correct.
Unfortunately, that doesn't work.
From the worker agent, the monitor comes on but the worker fails to start.
From the worker itself, if the monitor is turned off I can start the ugworker.bat and everything works fine.
I'm thinking there's some sort of pointer or typo somewhere.
HelesicPetr
Hi @Dobi
Try to configure the worker as new one.
Sometimes I copied the original config and I thought it should have been same but it wasn't
PetrH
Hello @Dobi ,
Go to Worker Agent Administrator -->Configure--> Select the Worker--> Edit Worker-->Step 5 Wizard Page--> Enable Auto Start.
Thanks & Regards
Shashwath Shetty
@Shashwath that's not it. Auto start is on already and the worker agent side of the configuration hasn't changed since I updated the Adapter version 6 months or so back.
Plot thickens (a little bit).
I have 3 NX CAD workers. Two of those are on VMs that also run Creo.
This particular one that is now not autostarting was working great along with one of the other systems that ONLY has the NX worker.
The other NX CAD worker on a shared VM with Creo is also not autostarting with the 10.1 adapters. 🤔
Dobi17-PeridotAuthorAnswer
Found the issue!
