Mar 5, 2024 6:56 AM UTC
CAD worker issue
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS24
Cad workers are getting failed automatically. could you please help us to resolve the issue.
if possible, please schedule the call to investigate and reproduce the issue.
    Mar 5, 2024 7:27 AM UTC
    @NC_10377719
    There are a lot of thing possibilities for CAD Workers to fail automatically. Kindly provide the details more.
    Point 1: NT or Cluster Configuration.
    Point 2: Creo or Third Party Software's
    Point 3: Enable the Allow list in WIndchill.
    Aj
    avillanueva
    23-Emerald II
    Mar 5, 2024 12:08 PM UTC
    First off welcome. Know that this is a community of users, not tech support. If you want a call directly, I would try that route. If you are getting an immediate failure, its likely that you have a firewall port block, worker daemon service is off or the command is wrong. Please explain your configuration, where you workers are located, OS, and possibly look for logs or a failure.
