Sep 28, 2017 12:31 PM UTC
CAD Worker Issues
Last night I decided to update to the latest datecode of CREO 3 on my CAD worker machine.  Instead of updating I reinstalled the software.  Now it is not connecting.  I've gone through all the threads on here that I could find and I'm not seeing errors where they are saying to fix.  So right now my CREO workers are down.  I have two workers configured on the same server.  Any help would be greatly appreciated.  I'm on Windchill 10.2 m030.  Thanks!
Sep 28, 2017 3:28 PM UTC
Thanks for pointing me in the right direction.  When I did that, I didn't realize that it overwrote the proeworker.bat file when I saved the configuration.  In it I needed to have the -DA <username> in the last name since I have two CAD Workers on the same machine.
22-Sapphire I
Sep 28, 2017 2:40 PM UTC
Likely the path to start Creo (Execute Command) in the creoview adapter on the CAD Worker needs to be edited to the new install path (e.g ...\Program Files\PTC\Creo 3.0\M110\Parametric\binM 140 vs. M130).  Launch adapter.pvi in that folder and select the new Creo Parametric start command in the UI, then save.  LIkely have to restart the daemon.
Likely can leave the CAD Worker Agent from Windchill Site alone.
BrianToussaint19-TanzaniteAuthorAnswer
