Apr 17, 2024 10:26 AM UTC
CAD workers on Cloud
When the CAD workers are installed in a separate VM. Is it necessary to have internet access on the VMs where CAD workers are running?
ShashwathAnswer
Apr 25, 2024 9:04 AM UTC
No. You don't need internet. In VM Network setting set it up to "bridge adapter" & add VM host name and IP Address of that machine to another machine & do it vice-versa. It'll work & I have test out too.
avillanueva
23-Emerald II
Apr 17, 2024 11:24 AM UTC
Certainly you need communication between the CAD worker VM and your server. There is a free license available from PTC for publishing that can be utilized which you can install local to the server. And of course you need to be able to administer it. But if you are asking if that CAD worker needs to be able to see the wider world, the answer should be no. If fact, its probably best that it cannot. I will make downloading and installing updates to CAD and WVS images tough but better for security.
Apr 18, 2024 8:47 AM UTC
so if i understand it correctly we can switch off the internet within the VM but keep it on the network to communicate it with the Windchill VM?
avillanueva
23-Emerald II
Apr 18, 2024 11:50 AM UTC
Yes, CAD worker would not be much use if it cannot communicate. But lock it down since it should only have to communicate with the Windchill server or servers. I have one that servers many Windchill instances.  Think from a security perspective. Least access principle.
Emeritus
Apr 22, 2024 12:33 PM UTC
Hi AP_10483126
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Shashwath12-AmethystAnswer
