Oct 22, 2024 8:20 AM UTC
Cadworker - jobs failed
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS11
We have a CADWORKER and the jobs are continuously failing, and at certain periods of time, it stops until we restart the server. After restarting the server, it converts again and stopped converting a few hours ago. I checked the server and found the same error as below.
Here are the errors that I faced
Job Log
Oct 22, 2024 8:24:32 AM:Start Job: Drawing - 64219-WB6.CATDrawing, 1A.1
Oct 22, 2024 8:24:32 AM:make temp dir D:\PTC\Windchill\temp\pubtemp\publish9018922536698913658.tmp
Oct 22, 2024 8:24:32 AM:"As Stored" Config Spec is available
Oct 22, 2024 8:24:32 AM:The EPMDocument As Stored Config Spec was selected as the default
Oct 22, 2024 8:24:32 AM:Start: Drawing - 64219-WB6.CATDrawing, 1A.1
Oct 22, 2024 8:24:32 AM:Authoring Application: CATIA V5
Oct 22, 2024 8:24:32 AM:Transferring Files to: D:\PTC\Windchill\temp\pubtemp\publish9018922536698913658.tmp
Oct 22, 2024 8:24:33 AM:Number of Files Transferred: 12
Oct 22, 2024 8:24:33 AM:CATIA Drawing Conversion
Oct 22, 2024 8:24:33 AM:Added request to CATIAV5 queue
Oct 22, 2024 8:24:33 AM:Job 4 submitted to worker: SHMSC013.hyundai.EUCORP.LOCAL-CATIAV5:1
Oct 22, 2024 8:24:33 AM:LOGID: worker_11.log
Oct 22, 2024 8:24:33 AM: Catia5_Access
Oct 22, 2024 8:24:33 AM: Downloading file using WWGM
Oct 22, 2024 8:36:03 AM:WWGM ERROR: lost connection to CATIA.
Oct 22, 2024 8:36:04 AM:Input File Not Found
Oct 22, 2024 8:36:04 AM:Drawing Processing Returned: $ERROR$ Input File Not Found
Oct 22, 2024 8:36:04 AM:Attempting to delete temporary workspace publish9018922536698913658tmp.
Oct 22, 2024 8:36:04 AM:Done deleting temporary workspace publish9018922536698913658tmp.
Oct 22, 2024 8:36:04 AM:CadAgent Returned: $ERROR$ Input File Not Found
Oct 22, 2024 8:36:04 AM:End (with Error): Drawing - 64219-WB6.CATDrawing, 1A.1
Oct 22, 2024 8:36:04 AM:End job (with error): Drawing - 64219-WB6.CATDrawing, 1A.1
Oct 22, 2024 8:36:04 AM:Publish Complete event dispatched
Oct 22, 2024 8:36:04 AM:remove temp dir: D:\PTC\Windchill\temp\pubtemp\publish9018922536698913658.tmp
Job Log
Oct 22, 2024 7:46:51 AM:Start Job: CAD Part - 92403-KL000.CATPart, 1A.1
Oct 22, 2024 7:46:51 AM:make temp dir D:\PTC\Windchill\temp\pubtemp\publish4046787622287167620.tmp
Oct 22, 2024 7:46:51 AM:"As Stored" Config Spec is available
Oct 22, 2024 7:46:51 AM:The EPMDocument As Stored Config Spec was selected as the default
Oct 22, 2024 7:46:51 AM:Start: CAD Part - 92403-KL000.CATPart, 1A.1
Oct 22, 2024 7:46:51 AM:Authoring Application: CATIA V5
Oct 22, 2024 7:46:51 AM:Transferring Files to: D:\PTC\Windchill\temp\pubtemp\publish4046787622287167620.tmp
Oct 22, 2024 7:46:51 AM:Number of Files Transferred: 1
Oct 22, 2024 7:46:51 AM:CATIA Part Conversion
Oct 22, 2024 7:46:51 AM:Added request to CATIAV5 queue
Oct 22, 2024 7:46:52 AM:Job 2 submitted to worker: SHMSC013.hyundai.EUCORP.LOCAL-CATIAV5:1
Oct 22, 2024 7:46:52 AM:LOGID: worker_10.log
Oct 22, 2024 7:46:52 AM: Catia5_Access
Oct 22, 2024 7:46:52 AM: Downloading file using WWGM
Oct 22, 2024 7:49:40 AM: Catia5_Read
Oct 22, 2024 8:19:40 AM:Timeout exceeded waiting for a reply from the CadAgent - Time out 1,800 seconds
Oct 22, 2024 8:19:40 AM:Part Processing Returned: $ERROR$ Timeout exceeded waiting for a reply from the CadAgent - Time out 1,800 seconds
Oct 22, 2024 8:19:40 AM:Attempting to delete temporary workspace publish4046787622287167620tmp.
Oct 22, 2024 8:19:40 AM:Done deleting temporary workspace publish4046787622287167620tmp.
Oct 22, 2024 8:19:40 AM:CadAgent Returned: $ERROR$ Timeout exceeded waiting for a reply from the CadAgent - Time out 1,800 seconds
Oct 22, 2024 8:19:40 AM:End (with Error): CAD Part - 92403-KL000.CATPart, 1A.1
Oct 22, 2024 8:19:40 AM:End job (with error): CAD Part - 92403-KL000.CATPart, 1A.1
Oct 22, 2024 8:19:40 AM:Publish Complete event dispatched
Oct 22, 2024 8:19:40 AM:remove temp dir: D:\PTC\Windchill\temp\pubtemp\publish4046787622287167620.tmp
    avillanueva
    23-Emerald II
    Oct 22, 2024 11:28 AM UTC
    I would do a knowledge base sweep on some of these unique error messages. I am no familiar with Catia but make sure that the part can open successfully without error in the CAD tool. You can also try using the interactive publisher to see what its seeing on the CAD worker.
    Dobi
    Oct 22, 2024 1:43 PM UTC
    Like @avillanueva, I don't have experience with CATIA but I did have to go through a lot of those errors on the NX side with the CAD worker.
    A couple of things that may be worthwhile looking at:
    - If the CAD worker is a VM,  you may be performance limited in terms of hard drive I/O speeds for large models. That means you'll hit the timeouts before the model publishes. With PTC tech support we did IOMeter logging (while publishing) to understand bottle necks and that helped root cause the particular behavior there. Turns out VMs are much better for Creo than NX...
    - Does the model open cleanly on your system? NX or Creo will sometimes have pop-ups or errors/warnings that the CAD worker may not know how to resolve... so it hangs. If everything opens cleanly on your system, you should be fine as long as the same settings for opening (in NX this is in the load_options.def file) exist on the CAD worker.
    - Increase the timeout. Some of our models are several GB and do (because of VM performance with NX) take a while to publish so upping the timeout was useful for the corner cases.
    - If you're publishing assemblies (which from those logs doesn't look to be the case), make sure you're publishing as "Positioning Assemblies". That's gets the timeout every time if it's a large BOM
    The first log with the "lost connection to CATIA" bit is curious... looks more like a Worker Daemon or Worker Monitor issue. Do you have multiple workers running on that same machine that are different CAD (like Creo and CATIA)? If yes, is your cache separated with environment variables?
    Catalina
    Community Manager
    Oct 25, 2024 6:48 AM UTC
    Hi @jsuresh,
    If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
    Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
    Catalina | PTC Community Manager
