3-Newcomer
May 13, 2026
cadwork發佈轉圖任務時提示無法連接到服務器,但手動打開是能註冊wgm應用服
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.0.0 cadwork發佈轉圖任務時提示無法連接到服務器,但手動打開是能註冊wgm應用服務器的 Here are the errors that I faced May 12, 2026, 5:36:48 PM:Start Job: CAD Part - 9998-052-00-00-422_000.prt, ABG, A.2 May 12, 2026, 5:36:48 PM:make temp dir $(publish.tempdir)/publish5314043062996791873.tmp May 12, 2026, 5:36:48 PM:The EPMDocument Default Config Spec was selected as the default May 12, 2026, 5:36:48 PM:Start: CAD Part - 9998-052-00-00-422_000.prt, ABG, A.2 May 12, 2026, 5:36:48 PM:Authoring Application: NX May 12, 2026, 5:36:48 PM:UG Assembly Conversion May 12, 2026, 5:36:48 PM:make temp dir $(publish.tempdir)/publish6273923450613374675ed May 12, 2026, 5:36:48 PM:Start: CAD Part - 9998-052-00-00-422_000.prt, ABG, A.2 May 12, 2026, 5:36:48 PM:Authoring Application: NX May 12, 2026, 5:36:48 PM:Transferring Files to: $(publish.tempdir)/publish5314043062996791873.tmp May 12, 2026, 5:36:48 PM:Number of Files Transferred: 1 May 12, 2026, 5:36:48 PM:UG Part Conversion May 12, 2026, 5:36:48 PM:Added request to UG queue for publish queue set PROE. May 12, 2026, 5:36:49 PM:Job 12 submitted to worker: AJ-PLM-SIT01-UG:1 May 12, 2026, 5:36:49 PM:LOGID: worker_1.log May 12, 2026, 5:36:49 PM:Downloading file using WWGM May 12, 2026, 5:36:52 PM:WWGM ERROR: Error from UWGM-Registration with server failed: The server couldn't be found at the given location May 12, 2026, 5:36:52 PM:Closing May 12, 2026, 5:36:53 PM:WWGM worker failed to sync file "9998-052-00-00-422_000.prt" May 12, 2026, 5:36:53 PM:Part Processing Returned: $ERROR$ WWGM worker failed to sync file "9998-052-00-00-422_000.prt" May 12, 2026, 5:36:53 PM:Attempting to delete temporary workspace publish5314043062996791873tmp. May 12, 2026, 5:36:53 PM:Done deleting temporary workspace publish5314043062996791873tmp. May 12, 2026, 5:36:53 PM:CadAgent Returned: $ERROR$ WWGM worker failed to sync file "9998-052-00-00-422_000.prt" May 12, 2026, 5:36:53 PM:End (with Error): CAD Part - 9998-052-00-00-422_000.prt, ABG, A.2 May 12, 2026, 5:36:53 PM:remove temp dir: $(publish.tempdir)/publish6273923450613374675ed May 12, 2026, 5:36:53 PM:UG Assembly, Number of Components Processed: 1 May 12, 2026, 5:36:53 PM:End: CAD Part - 9998-052-00-00-422_000.prt, ABG, A.2 May 12, 2026, 5:36:53 PM:End job (with error): CAD Part - 9998-052-00-00-422_000.prt, ABG, A.2 May 12, 2026, 5:36:53 PM:Publish Complete event dispatched May 12, 2026, 5:36:53 PM:remove temp dir: $(publish.tempdir)/publish5314043062996791873.tmp
