Feb 12, 2025 10:48 AM UTC
calculated attribute in part usage link
Version: Windchill 13.0
Use Case: I want have an attribute column in occurence tab whose data will updated automatically into the attribute column in uses tab in the product structure.
Description:
I have created an attribute(calculated) in part usage link and also created an attribute(global) in Uses Occurrence Attributes,and I would like to have the values from global attribute in Uses Occurrence Attributes to be in the calculated attribute in part usage link, so any input I make in product structure table to the occurrence attribute will be automatically updated in uses tab in the calculated attribute I have created.
but I am not able to use the internal name of the global attribute or the attribute internal name I created in Uses Occurrence Attributes to get this function
any suggestions?
Catalina
Community Manager
Feb 19, 2025 11:11 AM UTC
Hi @ED_12643325
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
