Jan 19, 2017 1:43 PM UTC
Can a windchill admin login as another user?
I have PDMLink users that have left the company with workspaces I want to access. At the very least I need to change the "context" of the workspaces. Is this possible?
TomU
Jan 19, 2017 8:54 PM UTC
You can change the context of a workspace but you would need to login to Windchill as that user.  This will require either knowing that user's password.
2-Explorer
Jan 19, 2017 9:02 PM UTC
Are you using Active Directory?  If yes, you can create a local user with the same user id as the user who left the company. Reconnect the disconnected principal. This will allow you to login as that user.
If you are using local LDAP, reset the password and login
