Dec 22, 2014 8:44 PM UTC
Can a Workflow task contain an option to "delegate" the task to another user?
Is it possible within a Windchill workflow task to have the option to "delegate" a task to another user? Currently the option available is "re-assign" the task. I realize that the entire workflow can be delegated to another user through calendar options, however, I would like the user to have the option to delegate their task while actually accessing their task. The reason we want "delegate" as an option within a task is that we do not want the task to return to the original user. Is this possible within Windchill 10.1?
Dec 22, 2014 10:03 PM UTC
The Customizer's Guide provides some example code for setting the object instance team based on Task completion. The example shown illustrates a "rework" task that is assigned to the user that completed an upstream task (they do this by assigning the completing user to a "rework" Role on the Team. I am looking at doing the same type of thing... probably easier for workflow only but could (in concept) be applied to something like a Change Task where the assigned roles are more visible.
