Can Google Workspace as the primary Identity Provider (IdP) for Windchill SSO implementation.
  • February 17, 2026
  • 3 replies
  • 117 views
Version: Windchill 13.1
Use Case: Implement Windchill with Single Sign-On using **Google Workspace** as the primary Identity Provider to enable secure, centralized user authentication.
Description:
1. Does Windchill support Google Workspace as a SAML 2.0 IdP directly?
2. Are there any known limitations or compatibility issues?
3. What Windchill version/modules support this configuration?
4. What attributes are required from Google IdP (email, name, groups, etc.)?
5. Can Windchill handle Just-In-Time (JIT) user provisioning from Google, or must users be pre-created?
6. Is there a fallback authentication method if Google SSO is unavailable?
7. Any additional components or licensing required for this setup?
Community Moderator
February 23, 2026
Hi @KL_11338253,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Best Regards,
Vivek N
Community Moderation Team
jbailey
18-Opal
February 25, 2026
Description:
Windchill should support any IdP that supports SAML 2.0 (based on Shibboleth)
Most issues with limitations or compatibility are configuration specific. If Windchill can reach the IdP, consume the IdP metadata, and trust the IdP certificates, there should be no/minimal issues.
Windchill supports SAML for all currently supported versions of Windchill
From an authentication standpoint, Windchill only cares about the username attribute defined in the shibboleht2.xml file and mapped with other xml files. There is no current functionality to map additional attributes from the SAML assertion. Additionally, the username attribute needs to match the unique user attribute mapped in adapterservise.josn in <wthome>\ieconf\
JIT / SCIM is not supported for Windchill, but I understand it may be on the roadmap for future implementation
Windchill is either configured for Basic, Form Based or IdP based SSO uniquely. Failback authentication would be a manual process where you would have to reconfigure for the desired failback.
For SAML & SAML IdP's following SAML 2.0, no licensing is required from PTC. It is up to the customer to provide an IdP.
Community Moderator
February 25, 2026
Hello @KL_11338253,
It looks like you have a response from a PTC community expert. If it helped you answer your question, please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
