6-Contributor
Jul 29, 2024 8:49 AM UTC
Can I extract requirement from windchill PTC
I am working on adding a custom widget to Windchill PTC. The widget's functionality is to export user stories to another application with the click of a button.
We have already implemented this functionality in IBM DOORS. I am attaching a reference video and am attempting to replicate the same functionality in WindChill PTC.
Answer
Jul 30, 2024 5:35 AM UTC
Exporting user stories from Windchill PTC to another application can be achieved through various methods. Let’s explore a few options:
Custom Widget Integration:
Since you’re working on adding a custom widget to Windchill PTC, you can create a custom widget that interacts with the Windchill API to extract user stories and export them to your desired format (e.g., CSV, JSON, XML).
The custom widget can include a button that triggers the export process when clicked.
You’ll need to handle authentication, query the relevant data (user stories), and format it appropriately for export.
Refer to Windchill’s API documentation for details on how to retrieve user stories programmatically.
Reports and Export/Import:
Windchill provides features for exporting and importing data, including reports.
You can create a custom report template that extracts user stories based on specific criteria (e.g., labels, status, project).
Export the report along with its supporting files (if any) using the “Export Reports” action.
Import the exported report into another Windchill system (e.g., a different server) using the “Import Reports” action.
Note that this approach is more suitable for periodic exports rather than real-time interaction.
Import/Export Management Utility:
Windchill includes an Import/Export Management Utility that allows you to move content and metadata between sites.
You can export user stories (and related data) from one Windchill system and import them into another.
This utility uses JAR (Java archive) files for data storage and extraction.
Copying Data Between Windchill Servers:
If you’re migrating data between Windchill servers, consider using the Windchill data copy process.
This process involves exporting data from one server and importing it into another.
It covers various Windchill modules, including PDMLink, ProjectLink, Pro/INTRALINK, and PDM Essentials
Hope this will help you.
Best regards
Florence Gayhart
Answer
Best regards
Florence Gayhart
6-Contributor
Jul 31, 2024 1:04 PM UTC
Thanks for helping me !!
Catalina
Community Manager
Jul 31, 2024 9:10 AM UTC
Hi @CC_11208265,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina | PTC Community Manager
