Sep 30, 2013 6:51 PM UTC
Can I force check-in comments?
Can I force users to add a comment every time they check in files?
Oct 6, 2013 7:50 PM UTC
Hi Mark,
The two jsps of check in wizard are
Windchill\codebase\netmarkets\jsp\wip\format_content_holder_checkin_step.jsp
and
Windchill\codebase\netmarkets\jsp\wip\non_format_content_holder_checkin_step.jsp
the textarea for putting comment <textarea wrap name="comment" id="comment" cols="53" rows="5"></textarea>
May be using javascript you can force user to make check in comments
Thanks and Regard,
Kaushik
Oct 7, 2013 3:37 PM UTC
You can use CSS .
class="required "
<textarea wrap name="comment" id="comment" cols="53" rows="5" class="required "></textarea>
Sep 1, 2015 8:33 AM UTC
Hi there,
I had the same problem.
How to force comments during "Check In" to PTC Windchill (Essentials)?
Solved by some tweaks in javascript.
Unfortunately, this does not work with auto-check-in.
Cheers
Matthias
Sep 4, 2015 6:05 PM UTC
Is there a way to prevent auto check-in (Creo File Menu action)?
Feb 26, 2016 4:28 PM UTC
I am afraid there is no way to deactivate auto checkin. Maybe in Creo 4 or 5.
