Aug 19, 2016 8:59 AM UTC
Can I generate response file through completion of change task by state based publishing approach?
Aug 22, 2016 3:00 PM UTC
The change Task is not a Releasable Object. If you want to publish ( I mean ESI) you have to have some workflow expression  to publish the ECN related to Change task.
Sudhakar
