Apr 6, 2016 8:09 AM UTC
can't understand the following error : ClassInfo that cannot be casted to LinkInfo
Hi there !
I have a problem that is very hard for me to understand.
I meet the following error :
wt.introspection.ClassInfo cannot be cast to wt.introspection.LinkInfo
How can this kind of error can comes from ?
Do it comes from links between java class or another cause ?
In my code, the problem is caused by the saving of an instance :
PersistenceHelper.manager.delete(instance);
but I delete it after saving it, It tell it in case this is a problem. I save the instance with that code :
PersistenceHelper.manager.save(instance);
here is the delete method :
public Persistable delete(Persistable paramPersistable)
  throws WTException
  WTHashSet localWTHashSet = new WTHashSet();
  localWTHashSet.add(paramPersistable);
  delete(localWTHashSet);
  return paramPersistable;
thank you !
