Feb 27, 2024 6:43 AM UTC
Can we Designate (and Lock) the PTC ootb parameters For Creo Parametric
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.2
Can we Designate (and Lock) the PTC ootb parameters For Creo Parametric (Like PTC_WM_MODIFIEDON, PTC_WM_REVISION etc). So that, we would like to use these parameters for downstream Processes. We would like to know the following conditions:
1. Can we Designate and Lock these OOTB Parameters
2. Would it be a Configuration or Customization
3. Are there is consequences if we Designate these OOTB Parameters
Here are the errors that I faced
    HelesicPetr
    Feb 27, 2024 8:56 AM UTC
    HI @NP_9305421
    All this PTC_WM parameters are part of the Windchill system attributes and are available for anyone who has access.
    This attributes are automatically added to the model during upload operation
    You can allow to create them before upload so you can modify them
    You just need to set creo config
    allow_create_pdm_param  to yes
    CS195124 - Custom Parameters are locked in Creo Parametric
    The article describes also a method how to open the PTCWM parameters
    PetrH
