8-Gravel
Dec 4, 2023 2:20 PM UTC
Can we generate the product service maintenance in Windchill 13?
We want to generate the reports to analyze the Product Servicing and maintenance history report from Windchill product configurations in Windchill 13.0. Are there capabilities to generate the report with historical data of the service and maintenance logs with dates?
Emeritus
Dec 11, 2023 9:33 AM UTC
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
AT_CADDM8-GravelAuthor
8-Gravel
Dec 14, 2023 4:29 AM UTC
Hello avillanueva,
We don't have Service Information Management in the Windchill installation. We have basic PDMLink installed, also, we have created configurations and instances of the base BOM. We just need to capture the servicing dates of the End Product, fill those in the Windchill, with updating serial numbers of the instances. So, in this case, when the product undergoes servicing, we get the new serial numbers of the rotable parts. We are expecting to get the report of all these services history tracked datewise. I have attached the snap-shot of a sample BOM of the instance.
HelesicPetr
Dec 14, 2023 1:01 PM UTC
Hi @AT_CADDM
You can use Baselines
Windchill PLM - Baseline
PetrH
avillanueva
23-Emerald II
Dec 11, 2023 2:53 PM UTC
Yes but you need to have the Service Information Management module installed. More information can be found below on capabilities.
https://support.ptc.com/help/wnc/r12.0.1.0/en/index.html#page/Windchill_Help_Center%2Fsublandingpages%2Fsis5002.html%23
8-Gravel
Dec 14, 2023 4:28 AM UTC
Hello avillanueva,
