11-Garnet
Apr 8, 2015 11:15 AM UTC
Can we prevent Promotion Request creators from selecting themselves as an Approver?
We want to prevent a user from approving their own documents. However, this users may be an approver of the same document type created by another user.
Apr 8, 2015 2:52 PM UTC
It is possible to use the available API's in an expression robot within the workflow, but I would like to see this as an available business rule that while still requiring an expression robot would be easier for most to implement
slapha
Jun 22, 2015 9:35 PM UTC
Not the easiest way but it's possible.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS180902
Someone else posted this as well as a method to check after the fact and remove them.
Solved: How to Check if Creater has added himself has a Pr... - PTC Community
