Apr 17, 2017 6:45 PM UTC
Can you host a Creo Parametric 4.0 installation on a virtual server and have it connect to a Windchill installation hosted on a separate virtual server?
Hi all, I have a bit of a quandary.
For a brief moment, I was able to host an installation of Creo Parametric on a virtual server, open Creo on my workstation, and connect it to another separate server that was hosting Windchill. Now when I launch Creo Parametric and click on the server manager, Creo throws an error: "The server is not supported." Does anyone have any experience with an issue like this?
TomU
TomUAnswer
Apr 18, 2017 4:20 PM UTC
At this point I would probably try two things.
  1. Open a case with tech support and see if they have any ideas.
  2. Install Wireshark or Fiddler and see it you can identify the call that is failing.
TomU
Apr 17, 2017 7:42 PM UTC
Assuming the versions of Creo and Windchill are compatible, I would suggest removing your local cache and then using the environment variable PTC_WF_ROOT to control where this cache is being created.
kkillian1-VisitorAuthor
Apr 17, 2017 7:56 PM UTC
I am running the latest versions of both Windchill and Creo Parametric.
Okay, so this cleared all of the servers in the server manager.
After running a script setting this variable to a temp folder on my C:\ drive, I attempted to register my Windchill server with the server manager. This resulted in an invalid server location error. I know the server exists, and I have had an admin open all of the ports (so this shouldn't be a port problem), so do you know what the stumbling block is?
TomU
Apr 17, 2017 8:15 PM UTC
Can you access the server from a standalone browser?  The url is exactly the same for Creo (up through the Windchill part).  Keep in mind that it's case sensitive (capital 'W'.)
http://<server name>/Windchill
