Dec 26, 2024 7:06 AM UTC
Cannot validate mount in Windchill 9.0
Version: Windchill Below 11.0
Use Case: I tried vilate mount in Windchill 9.0 but I couldn't do that and get the below message "Some mounts are incorrect" I checked a vault and relate folder and there were no any suspects. How to fix this?
Description:
Dec 26, 2024 2:39 PM UTC
Is this a new build of Windchill 9.0 or an update from an earlier version?
Windchill 9 is very much out-of-date!
DamienL10-MarbleAuthor
Dec 26, 2024 3:01 PM UTC
This is an old one.
we have to resolve this and then will upgrade to latest version.
Dec 26, 2024 4:28 PM UTC
Is your Host system correct?
Is the Path correct as shown in the Vault Configuration under Main Folders?
Check that you can access the vault mount point.
Maybe a screen shot might help.
Your upgrade from Windchill 9 will take multiple steps and upgrades. I know you cannot go beyond 11.2 before going to 12 or 13. I am not sure what you need to go to from 9 as the intermediate step.
Dec 27, 2024 12:20 AM UTC
Here is a screen.
마운트 상태 / Mount Status
알수없음 / UNKNOWN
upload_-PT91dGYtOD9RP25zPTVGYXR0YWNoPTVGaW1hZ2U9NUY4NTg0NDE3MzUyNTg3ODg5MzMucG5nPz0=-6963727835204896115..png_=
Fadel
23-Emerald II
Dec 27, 2024 3:09 PM UTC
any error in ms log when you see this error
Buiꓘa
Dec 28, 2024 12:09 PM UTC
For a mount to validate...
  1. Broadcasting must be successful.
  2. The mount path must exist: //arch/ptc_vault/20190805.
  3. The user account that runs Windchill must have read/write permissions to the mount path.  To test, write a file to the UNC path as that user.
  4. Before 12.1, there cannot be a site_* file from another Windchill instance in the MOUNT_VALIDATION_FOLDER.  Delete the file and try to validate again: //arch/ptc_vault/20190805/MOUNT_VALIDATION_FOLDER/site_*.
  5. If Windchill is configured for HTTPS, install Windchill's SSL Cert with the Windchill file vault server as named in Site > Utilities > Vault Configuration.
