22-Sapphire I
Dec 17, 2018 10:31 PM UTC
Cascading Attributes in Windchill
There are multiple postings on Cascading Attributes and some pretty good articles.
Finally tried - took me a little while to get all details right.
I'm attaching a little cheat sheet - may help someone.
7-Bedrock
Dec 19, 2018 9:32 PM UTC
This feature is available only from Windchill 11.1 onwards.
2-Explorer
Dec 19, 2018 10:39 PM UTC
I'm still on Windchill 11.0 but very interested in Cascading Attributes.  I'm wondering how they use (if they use) any pre existing attributes?
James
Dec 26, 2018 10:59 AM UTC
The cascading attribute rule, an attribute must have a string data type, and a single, enabled enumerated value list constraint directly backed by a global enumeration.
Jan 30, 2019 11:49 AM UTC
Hi
Is there any solution to bring cascading of attributes in Windchill 11.0 M030 through customization.
We have a requirement for this use case?
Has anyone implemented the same?
Feb 5, 2021 1:59 PM UTC
Yes Through Customizations ,you can achieve cascading of attributes in Windchill 10.2/11.0.
Steps:
1)Write DataUtility for cascading  attributes.
2)write javascript function (within onscope jsp page).
3)Call that Java script function from datautility (for onchange event).
4)Make Ajax call within Javascript function.
Hope this will help.
Do let me know if you stuck somewhere while writing code.
6-Contributor
Apr 25, 2024 5:42 AM UTC
Hi Ritesh,
Can you provide datautility class for the same.
