Change Life cycle state of Document using webject?
is there any webject available to change life cycle state of an object?
Hi Giri, Did you try to check out the object and then update the value of the attribute? I have written a webject to update description attribute of ePMDocument. You can use it for other object.
<ie:param name="WHERE" data="number='ObjectNumber"/"> <ie:param name="TYPE" data="wt.epm.EPMDocument"/"> <ie:param name="GROUP_OUT" data="pbo"/">
<ie:param name="ATTRIBUTE" data="number,description" delim=","> <ie:param name="WHERE" data="number='ObjectNumber"/"> <ie:param name="TYPE" data="wt.epm.EPMDocument"/"> <ie:param name="GROUP_OUT" data="epmdocs"/">
<% com.infoengine.object.factory.Group pbo = getGroup("epmdocs"); String checkoutState = (String) pbo.getAttributeValue(0, "number"); System.out.println("stateeeeeee==="+checkoutState); String moddescrip = "Descriptionnnnnnnnnnnn";%>
<ie:webject name="CheckOut-Objects" type="ACT"> <ie:param name="OBJECT_REF" data="${epmdocs[0]obid[0]}"/"> <ie:param name="GROUP_OUT" data="checkedOut"/> </ie:webject>
<ie:webject name="Update-Objects" type="ACT"> <ie:param name="OBJECT_REF" data="${checkedOut[0]obid[0]}"/"> <ie:param name="field" data="description='&lt;%=" moddescrip=" %=">"/></ie:webject>
<ie:webject name="CheckIn-Objects" type="ACT"> <ie:param name="OBJECT_REF" data="${checkedOut[0]obid[0]}"/"> <ie:param name="GROUP_OUT" data="output"/"> </ie:webject>
Hope this helps.ThanksSitanshu
Thanks Sithansu!
