Nov 2, 2011 7:00 PM UTC
Change Management Tutorial
Hello Windchill Users
I wanted to inform Windchill users that there is a Change Management Tutorial that I written on the below webpage. The tutorial explains the Windchill out-of-the-box functionality with screen shots that displays each step of the process with the Change Management basic workflow. Select on a blue box and you will see a pop up window showing the steps. I hope this helps.
http://www.felcosolutions.com/cm2process.html
The web site also has some other information that explains the CAD Workspace interaction with Windchill and a common Glossary of the Windchill terms. The URL links are below.
http://www.felcosolutions.com/workspace.html
http://www.felcosolutions.com/glossary.html
I hope this helps some of you and you can pass this information on to others too.
Thanks and have a nice day!
Dec 28, 2011 5:55 AM UTC
Dear James,
Thanks very much. The tutorial on CM was of great help to me.
It would be great if you could throw some light on Windchill UI customization. I am fairly new to WC.
Raghu
18-Opal
Aug 17, 2017 2:13 PM UTC
The workspace link is the only working link.  The other two are broken.
Aug 25, 2017 9:16 PM UTC
@jfelkins
Only one of the links you posted work.
