Jun 16, 2016 7:17 PM UTC
Change Notice Attachments
So, we just completed our update to 10.2 and everyone is getting back into the swing of things.
One item I'm having trouble fixing is how to add an attachment to a Change Notice (or a Change Task). In 10.1 there was a little java drag and drop icon in the are circled. It's missing in 10.2 even with the compatible java version (8u25+).
I tried a few searches in Knowledge base with no success.
Can anyone spare a clue and let me know what I'm missing here?
Jun 16, 2016 7:26 PM UTC
Is your 'File Upload Mechanism' preference set to 'Use Java Applet Functionality'? If not, the drag and drop icon won't appear.
Jun 17, 2016 12:04 PM UTC
It wasn't. Now that it is, at least something shows up. But still not quite there yet.
Jun 21, 2016 1:03 PM UTC
What version of Java is installed?
If it's 7 then you need to add the URL base to the java control panel.  On the Security tab in the Exception Site List.
Jul 8, 2016 11:12 AM UTC
I gave up. I installed various versions of Java that supposedly work and couldn't get anything going. So it's back to browser functionality. My user base has already gotten used to that method anyway.
Thanks for all the suggestions.
Jul 8, 2016 6:00 PM UTC
Did you enter the website to your PDMLink in the Java control panel exception site list?
Jul 21, 2016 9:15 PM UTC
Java applet for file upload exists in 10.2 M10 and lower. If you upgraded to higher version, then it should not exist there.
23-Emerald II
Jul 21, 2016 9:37 PM UTC
Do you have this documented somewhere? I just tested in my 10.2 M030 system and I am able to see the Drag and Drop icon in my New Change Notice > Set Attachments screen if the Attachments > File Upload Mechanism preference is set to use Java applets:
The 10.2 M030 "Content Management" WHC topic also still mentions the availability of being able to use Java applets for the file upload mechanism: http://www.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=AttachmentDownloadUploadPrefRef&action=show
Also, I came across this article, which addresses the currently known plans for handling Java applets within Windchill:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS160578
