jbailey
18-Opal
Mar 11, 2024 1:51 PM UTC
Change Notice Template / Implementation Plan / Assignee
Running into a scenario where I have a process that would have a set group of activities in a change plan that would be assigned to certain known individuals.
I know in the Change Notice template you can create an implementation plan, however users would have to still have to be manually assigned as assignee / reviewer (if applicable).
Has anyone approached this before and have a viable solution? I am not opposed to sub-typing the Change Notice or Change Activity type.
Mar 13, 2024 5:40 AM UTC
I think in the CN template itself, you can have the implementation plan templated with pre-determined Context Roles allocated to Assigned and Reviewer. Have you tried pre-casting the Imp Plan with context roles?
The users in the context roles will be notified, and its as usual, who ever picks the task first , typical WF stuff.
I think it can be worth a try.
Best Regards
Hari
jbailey
jbailey18-OpalAuthor
18-Opal
Mar 18, 2024 6:23 PM UTC
I looked at that, but I didn't dive too deep yet- figured I would see if anyone else in the community had some practical examples of how they are doing it today.
Oct 17, 2024 4:26 PM UTC
