Aug 11, 2016 8:27 AM UTC
Change Unit of Failure Rate: FPMH->FIT
does anyone know how to Change unit of predicted Failure Rate in Windchil Quality Solutions/Prediction from FPMH to FIT?
Andi
Dec 13, 2018 9:38 AM UTC
General Support File Properties
Failure Rate Multiplier
The units in which to display the failure rate. This property is available in several FTA, RBD, and Prediction files. The default is 1000000 because the units for failure rates are most commonly failures per million hours. However, you can change the units. For example, you might change the units to 1000000000 to base calculations on failures per billion hours, which is also known as FITS (failures in time).
