3-Newcomer
Jul 14, 2025 9:14 AM UTC
Changing the quality classificaion tree using XML importer
Version: Windchill 13.0
Use Case: Say, we have a large classification tree that has some nodes that need to be moved, others need to be added or deleted automatically.
Description:
We do not want to do this task with hand (as it will take a lot of time and need to be done on our QA environments first). We also want a script to do this so that in the future, when the tree changes according to our business needs it can be easily done. Though when I was looking for any documentation on how to do this I could not find anything to help me. Currently i am trying to insert a new child node of a child node: root > classification > new node trying to import the following file:
<?xml version="1.0"?>
<!DOCTYPE NmLoader SYSTEM "standardX26.dtd">
<NmLoader>
    <csvLoader>
        <objectType>com.ptc.windchill.enterprise.iba.classification.ClassificationNode</objectType>
        <csvFile csvSeparator="," isLoadFile="false">
                        Name,DisplayName,ParentNodeInternalName,Description
                        NEW_TEST_NODE,New test node,NonconformanceCategoryTree,This node is used completely and only for testing.
            </csvFile>
    </csvLoader>
</NmLoader>
Trying to import this only gives error that it can not read the file.
Catalina
Community Manager
Jul 18, 2025 9:33 AM UTC
Hi @JB_13666138
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
