Aug 27, 2025 5:07 PM UTC
Check in again a file but emptying an attribute
Version: Windchill 12.1
Someone made a check-in but filled in the wrong attribute field.
Now I need to fix it by leaving it blank, but when I try to check in, it says that I can't do that because the field cannot be removed. Any ideas on why this is happening and how to fix it?
Just to add, the field is a string and have no restrictions, and it's an asm file.
avillanueva
23-Emerald II
Aug 27, 2025 6:46 PM UTC
avillanueva
23-Emerald II
Aug 27, 2025 6:44 PM UTC
What is the exact text of the error you received?
avillanueva
23-Emerald II
VR_400014-AlexandriteAuthor
Aug 27, 2025 6:47 PM UTC
exactly that, I guess the only solution is using the CAD...
