Apr 10, 2016 3:39 PM UTC
check promotion item
How do I check if the promotion target is in the other promotion notice by using the code ?
Thanks!
20-Turquoise
Apr 11, 2016 2:03 PM UTC
Thanks!
You can use this:
MaturityHelper.service.getPromotionNotices()
20-Turquoise
Thanks!
You can use this:
Apr 11, 2016 3:22 PM UTC
You can use wt.maturity.MaturityHelper.service.getPromotionTargets() to get the target objects and then as mentioned in the above response you can find related promotions notices using MaturityHelper.service.getPromotionNotices()
Bhushan
è吕1-VisitorAuthor
Apr 12, 2016 5:46 AM UTC
Thank you.
