Feb 21, 2023 6:39 PM UTC
Clipboard size restriction
The default clipboard size is 250, the models my company generates are far larger (average 5k, however, 15k files is not out of the realm of possibilities). Inside a change notice anything after 1000 causes massive delays if it ever completes. How else do I add the items to the Affected Items box or include them as part of the change?
HelesicPetr
Feb 22, 2023 9:52 AM UTC
Hi @agarr
Have you ever used the collector inside of change table? It can collect many linked objects
or you can increase clipboard limit more info in  Windchill-Clipboard-limit
PetrH
agarr10-MarbleAuthor
Feb 22, 2023 3:29 PM UTC
@HelesicPetr I tried moving the clipboard limit to 2500 and the system will hang and never complete for the finish step of the Change notice creation. For ~2400 items in a change notice it took over 2 minutes just to revise. I can't get it to finish over 2500 items, doesn't matter how I start or using the collector. Moving to the Affected items box is delayed but completing the change notice is worse.
