Jul 14, 2014 1:55 PM UTC
Clustering in 10.2
Is the clustering procedure differenr in windchill PDmlink 10.2 version?
I have followed manuel proceudre for configuring cluster but I heard there is a different procedure in 10.2.
Could you pease explain the procedure followed in 10.2 version of windchill?
Jul 14, 2014 2:08 PM UTC
Yes, the process is different (and much simpler).
See the product documentation.
Jul 18, 2014 6:22 PM UTC
The documentation for configuring a cluster is in the Advanced Deployment guide, under the chapter "Installing and Configuring a Cluster Windchill Environment":
http://www.ptc.com/WCMS/files/156979/en/WCAdvDeployGuide.pdf
ManojC1-VisitorAuthor
Apr 8, 2015 1:41 PM UTC
I have another concern ,
How Windchil directory service is managed in 10.2 clustered environment?? If master goes down then one of the salve would become master and how it will communicate with WDS?? are there separate instance of it ??
If the physical machine down then it is like whole system down if WDS is not accessible. please clarify this.
Regards
Manoj
Feb 10, 2016 12:24 PM UTC
For this you need to configure  Windchill DS Replication in all the Nodes, so when DS goes down in Master , Slave will be active with Slave DS replication.
Nandish
