Jan 12, 2016 2:04 AM UTC
Cognos error - RQP-DEF-0177 An error occurred while performing operation 'sqlScrollBulkFetch' status='-232'
Hi All,
I have a strange Cognos error that PTC is having a hard time diagnosing. I have Cognos installed correctly and double checked all of the db.properties. We have Windchill cluster environment 10.2 M030 CPS 09. Cognos is installed in other node which is not a part of Windchill cluster.
I can also successfully login to Cognos's web UI and update the model/load reports. Authentication works fine as well.
1. All QML reports are working fine.
2. Infoengine reports with less data is working fine but when we are trying to run report with (50k rows), it's working for 200 rows, it's failing with below error:-
Original Error: RQP-DEF-0177 An error occurred while performing operation 'sqlScrollBulkFetch' status='-232'.  UDA-SQL-0528 The XML parser returned the following message: "General XMLParser Error!".  UDA-CUR-0000 Unable to fetch the row.  RSV-SRV-0042 Trace back:  RSReportService.cpp(729): QFException: CCL_CAUGHT: RSReportService::processImpl()  RSReportServiceMethod.cpp(258): QFException: CCL_RETHROW: RSReportServiceMethod::process(): asynchWait_Request  RSASyncExecutionThread.cpp(848): QFException: RSASyncExecutionThread::checkException  RSASyncExecutionThread.cpp(305): QFException: CCL_CAUGHT: RSASyncExecutionThread::runImpl(): asynchRun_Request  RSASyncExecutionThread.cpp(904): QFException: CCL_RETHROW: RSASyncExecutionThread::processCommand(): asynchRun_Request  Execution/RSRenderExecution.cpp(591): QFException: CCL_RETHROW: RSRenderExecution::execute  Assembly/RSDocAssemblyDispatch.cpp(323): QFException: CCL_RETHROW: RSDocAssemblyDispatch::dispatchAssembly  Assembly/RSLayoutAssembly.cpp(79): QFException: CCL_RETHROW: RSLayoutAssembly::assemble  Assembly/RSDocAssemblyDispatch.cpp(417): QFException: CCL_RETHROW: RSDocAssemblyDispatch::dispatchChildrenAssemblyForward  Assembly/RSReportPagesAssembly.cpp(178): QFException: CCL_RETHROW: RSReportPagesAssembly::assemble  Assembly/RSDocAssemblyDispatch.cpp(367): QFException: CCL_RETHROW: RSDocAssemblyDispatch::dispatchAssembly  Assembly/RSPageAssembly.cpp(314): QFException: CCL_RETHROW: RSPageAssembly::assemble  Assembly/RSDocAssemblyDispatch.cpp(367): QFException: CCL_RETHROW: RSDocAssemblyDispatch::dispatchAssembly  Assembly/RSTableRowAssembly.cpp(177): QFException: CCL_RETHROW: RSTableRowAssembly::assemble  Assembly/RSDocAssemblyDispatch.cpp(367): QFException: CCL_RETHROW: RSDocAssemblyDispatch::dispatchAssembly  Assembly/RSTableCellAssembly.cpp(151): QFException: CCL_RETHROW: RSTableCellAssembly::assemble  Assembly/RSDocAssemblyDispatch.cpp(417): QFException: CCL_RETHROW: RSDocAssemblyDispatch::dispatchChildrenAssemblyForward  Assembly/RSDocAssemblyDispatch.cpp(367): QFException: CCL_RETHROW: RSDocAssemblyDispatch::dispatchAssembly  RSResultSetIterator.cpp(1472): QFException: CCL_RETHROW: RSResultSetIterator::retrieveData  QFSPartialDataset.cpp(80): QFException: CCL_RETHROW: QFSPartialDataset::GetEdgeIterator  Source/QEDmResultSet.cpp(75): QFException: CCL_THROW: QE
Appreciate If anyone can provide any suggestion/inputs on this.
rajivranjan.kumar@allegion.com
3177968382
2-Explorer
Jan 12, 2016 3:13 PM UTC
This error just says the Cognos is not able to get result from the datasource through XML4Cognos. It is very generic error.
  • Do you have query governors set in Cognos? like Query Execution Time limit or Maximum number of rows retrieved. Also for testing disable the local cache for the queries used
  • Do you have any query limits set in wt.pom.paging.snapshotQueryLimit  or wt.pom.queryLimit? What if you run an Info*Engine task that has more than 200 rows as result from a web browser or IE task editor? May be a basic task to fetch all the documents
Thank you
Binesh Kumar
rkumar-51-VisitorAuthor
Jan 12, 2016 3:37 PM UTC
Thanks a lot Binesh for your response.
Can you pls suggest how to set query governors/disable local cache in Cognos?
QueryLimit is set to unlimited(-1). If we run full report(50k rows) from web browser, it fails to display and throws "timeout error". PTC said we cannot have such long open session. At present, we are downloading the report(in XML to XLS format) on WC Server (20 MB in Size), it takes 15 minutes to download the report. Now we are trying to run the same Infoengine task through Cognos.
Thanks in Advance,
Rajiv
2-Explorer
Jan 12, 2016 11:18 PM UTC
It is set in query hits in Cognos Query properties. In the query explorer, navigate to query properties.
But I don't this that is the problem here, 15 minutes for 50k rows sounds really bad from a performance standpoint.  You need to identify were the bottleneck is - info*engine query / server/ database ? If you have PSM installed, it has a Business Transaction for " Cognos Interactions" , you can use this to identify the transaction captured through URI  /servlet/XML4Cognos.
Also try profiling the action on the server database and see whether you can optimize the query.
Thank you
Binesh
Mar 5, 2016 4:43 PM UTC
Hello Rajiv,
I faced exactly same error while running any of cognos report. Please check MS logs as it will give exact error of failure. My issue got resolved after adding IP of Cognos server
in wt.auth.trustedHosts property in wt.properties. Also map ip address of gateway server in host file of cognos host server if you are using distributed architecture of cognos.
Exact error from MS log will help to drill down your issue.
Jayesh
