Jan 19, 2015 9:31 AM UTC
Cognos Reporting : Prompt Page
I am in the process of creating a prompt page for a Cognos report. I*E task is the data source for the same. I know, one can create a prompt page by simply adding @param to the task
Ex:
@param java.lang.String Number
The above provides a simple text box on the prompt page. Would you be able to tell me how can we have a drop-down or radio box as input on the prompt page ?
The values from the prompt page will be read in the I*E task before the task is fired. The input value will form a part of the where clause for the task.
Malavika
Jun 9, 2015 11:42 AM UTC
Hi Malavika
Were you able to get a solution to this? I am looking for something similar. I don't think it will be possible using anything on the task. A template will have to be created.
Pardeep
mrane1-VisitorAuthor
Jun 9, 2015 11:47 AM UTC
Unfortunately, I haven't found a solution just yet.
Jun 9, 2015 11:51 AM UTC
Have you tried a custom page?
