Apr 7, 2021 10:22 AM UTC
Cognos to Jasper migration
Hi all,
Will there be help in WC 12 for people upgrading from WC 11 with many Cognos reports, to help them migrate the reports to Jasper?
thanks -- Rick
Nov 3, 2021 7:31 PM UTC
Some background information for the thread
  1. Customers who have Windchill Business Report Author (Cognos) will be able to continue to use Cognos and their custom reports through the Windchill 12.0.2 release stream
    1. Cognos will not be shipped or available for Windchill 12.1.0.0 and beyond
  2. Customers should plan to transition any custom reports to JasperReports Library during the Windchill 12.0.2 timeframe.
    1. Information on creating custom reports with JasperReports Library can be found in Help:  Jasper Report Customization in Windchill
  3. There are no tools or frameworks to convert a report from one BI framework to another.  Any custom reports will have to be recreated.  Data sources such as Query Builder and Info*Engine can be reused in creating reports with JasperReports Library
  4. There is a an FAQ that can be found on the Support site here:  FAQ: Cognos to Jasper Reports
Apr 12, 2021 1:54 PM UTC
I also have this question!
rleir17-PeridotAuthor
Apr 13, 2021 2:34 PM UTC
And more generally, how long can we continue to use the old Cognos reports? Someone said that they would continue to run until 12.01 but you should consider that hearsay. And that the out-of-the-box Cognos reports would be converted to Jasper by PTC? But if, further to that, you wrote more Cognos reports you might need to acquire a Cognos license from IBM? There are several questions above, please help!
cheers -- Rick
Jun 25, 2021 8:12 AM UTC
Hello Rick,
Not sure of you got the answer to your request, just found it. to answer your questions:
  • PTC will provide the OOTB Cognos Report with Jasper
  • Customers will need to migrate their custom reports themselves  as this is third party to third party migration, there are few hints online (convert the cognos reports into xml's for easy reading through the SQL and then create new jrxmls)
  • Cognos will be supported with Windchill versions and will be discontinued starting 12.1.0.0
  • until 12.1 the normal use of Cognos is still in place.
I hope this helps
Nisrine
Nov 4, 2021 9:51 AM UTC
Hi Jeff
Thanks for that info.
In point 4, the FAQ that you link to gives me :
"Note: This article 352015 is not customer visible."
Rick
Nov 4, 2021 1:37 PM UTC
@rleir The article should be available today if it is not already.  Sorry for the confusion.
